Thread: coilover vs. springs/struts
Showing results 1 to 5 of 5
    mjc1055
    what, exactly, is the difference between buying coilovers vs. buying new springs and struts? why are coilovers so much more expensive?
    Coilovers - Offer flexibility..with them you are able to adjust your ride height on all 4 corners.. normally 0-4"
    Springs- Drop the car a specific distance.. normally from 1.4-2.2 (estimate)
    Struts- Option to replace with eith Coilover or Spring setup.. will improve the ride quality.. normal bounciness with coilovers or springs with stock struts..
    Hope this helps.. if not.. DO A SEARCH!
    12-17-2002
    Sherman Oaks, California
    4,304
    yeah, that was pretty much it. just make sure you dont get shitty coilovers like i did, or else it'll slam your ride down to the ground and you'll be bouncing all over the place, despite the insane handling quality.
    http://socallifestyle.com/
    1994 Galant GS 5spd
    mjc1055
    <div class='quotetop'>QUOTE(ChromeGalant)</div><div class='quotemain'>Coilovers - Offer flexibility..with them you are able to adjust your ride height on all 4 corners.. normally 0-4" Â*
    Hope this helps.. if not.. DO A SEARCH! Â* </div>
    out of curiosity, how much work is involved in adjusting the ride height? is it just loosening/tightening a bolt or two or is it more complicated than that
    Very simple... jack up a corner, loosen a screw.. twist to desired height , tighten screw.. the lower..
    just that simple..
