Thread: Coilover Install Question, Help Me Out
Showing results 1 to 6 of 6
    xpr626
    I have a 96 Galant, and I am going to install coilovers. What are the factory specs for how much I should torque the bolts on the suspension that I will be removing?
    Thanks!
    brandon
    Specs, who uses specs?
    haha
    xpr626
    I just want it done right, or semi right, half assed even. I just don't want the damn suspension falling apart.
    brandon
    As long as you tighten em and re-tighten em after a bit of driving you should be fine.
    I don't think anyone who's lowered their Galant here has torqued back to specs (at least the majority haven't).
    xpr626
    Thanks for the help! Sorry I don't know much about suspension systems. :oops:
    San Antonio, Tex-Mex
    1,413
    You could always go buy a Chilton's manual, they have torque specs in those.
    <-Check it out Maz
    My 7g
