<div class='quotetop'>QUOTE(Rallifan)</div><div class='quotemain'>I'm thinking ahead to my 30k/2 year service and was wondering if I should have my engine and tranny fluids flushed while I'm doing the maintenance, or if it's just a waste of money on another of the dealer "gotchas."</div>
waste of money.
changing them normally is more than enough.
its not harmful, but its not doing anything fancy.
the engine oil flush is a bigger waste of money than the trans flush, as you only get about 50 percent of the fluid out during a trans service.. so a "Flush" will get more fluid out.
that said, todays trans fluids are damn stout. personally, i recommend changing it once a year due to the ease of it on the new galants.. just drain and fill.. takes no longer than an oil change.
