Thread: What kind of engine?
Page 1 of 3 123 LastLast
Showing results 1 to 20 of 49
    05-14-2003
    Southern California
    1,404
    Anyone know what kind of engine is the 9G using? I mean I know its 3.8L and MIVEC. But is it based on the 6G72 at all? Also anyone else as anxious as I'am to race the 9G's v6 against the 8G's v6?
    Im waiting to spank a 9g just like i spank the 8g's :twisted: :twisted: :twisted:
    YES I STILL HAVE MY GALANT!!
    05-14-2003
    Southern California
    1,404
    Quote Originally Posted by MidNightRacing
    Grrr, let me guess...7G w/5 spd. Correct?
    BTW What does your avatar say?
    Nope auto! 8)
    Ask Kho that's him
    Says some think bout a apple slurpie
    05-14-2003
    Southern California
    1,404
    Nope auto! 8)
    Ask Kho that's him
    Hehe Kho's slupry's are gay. Come to my store, we have the bombest slurpys around.
    BTW Are you using any type of FI? Cause if not then I really doubt you can beat a 8g v6.
    Re: What kind of engine?
    <div class='quotetop'>QUOTE(Jet BLaK)</div><div class='quotemain'>Anyone know what kind of engine is the 9G using? Â*I mean I know its 3.8L and MIVEC. Â*But is it based on the 6G72 at all? Â*Also anyone else as anxious as I'am to race the 9G's v6 against the 8G's v6? </div>
    Yes its 'loosely' based on the 6G72 meaning the basic block is similar but it has been adjusted for the increase in displacement.
    Btw the engine code is 6G75 and 4G69
    More specs here -----> http://www.mitsubishicars.com/2004galant/f...res_specs2.html
    BTW Are you using any type of FI? Cause if not then I really doubt you can beat a 8g v6.</div>
    I know i can bet the i4 dont know about a v6 8G
    <div class='quotetop'>QUOTE(RedGalant2k1)</div><div class='quotemain'>More specs here ----->http://www.mitsubishicars.com/2004galant/features_specs2.html</div>
    DAMN look @ this fat bitch:
    GVWR (lbs/kg)
    4320/1960
    4320/1960
    4486/2035
    4540/2060
    4AT Curb Weight (lbs/kg) [w/ sunroof]
    3351/1520 [3373/1530]
    3560/1615 [3583/1625]
    3649/1655
    First one: Red 88 - 245whp/312wtq - HIN: Nightshift - Chicago '07 WINNER
    Second one: Durban 88 - Buckskin - SHP - Auto - Sold to more capable hands
    Next one: White 84 flatty - t3/t4 - VELNAS - More to come
    "...Remember: Don't crush 'em, restore 'em!"
    Quote Originally Posted by Mazarin
    Quote Originally Posted by RedGalant2k1
    GVWR (lbs/kg)
    4320/1960
    4320/1960
    4486/2035
    4540/2060
    3649/1655
    damn they are making the car bigger and bigger year Generation...
    AkA K h O p A r I.
    I Am back BitcheZzZ
    07-20-2003
    Orlando, FL
    3,169
    Thats because Americans are getting more FAT every year! 8)
    Quote Originally Posted by 4rced4door(-G-host)
    no Ghost let me Correct that.. Philly People are GEtting fat Every year.
    AkA K h O p A r I.
    I Am back BitcheZzZ
    CrazyGalant
    it's a 6g75 base on the diamante also found on the endeavors
    04 GTS
    can't wait. :twisted:
    05-14-2003
    Southern California
    1,404
    <div class='quotetop'>QUOTE(04 GTS)</div><div class='quotemain'>can't wait. Â*:twisted:</div>
    I can after seeing that weight-to-power ratio. Makes me want to cry. Mitsu took a step forward, and 2 steps back (quoted of some other user).
    Member
    08-19-2003
    Trenton, New Jersey/Tampa, Florida
    219
    do you think that the 9G will be faster than the current 8Gs--hp in the GTS is like 230 vs 195 for GTZ--but the weight--damn--mitsu needs to get away from heavy ass cast iron blocks--try aluminum--that would be a good idea and save like 300-400 lbs...hmmm
    Mayonnaise colored Benz---I push Miracle Whips
    -K. West
    Member
    08-19-2003
    219
    sorry for the double post--but what I think would be really hot is if Mitsu stop punkin out and stop making me-to products barely matching the other Japanese manufactures (Honda/Nissan/Mazda (kinda)) and did something different like putting going on a limb--designing a car then putting a class leading engine in it. Up the anty alittle, kinda like what Nissan/Infiniti did with M45 (even though the car IMO is kinda plain looking) the engine--lawd--the engine is ridiculous 340 hp 333ft/lbs torque V8--makes those Lincoln LS V8 drivers sick to their stomach...
    -K. West
    BXNYMitsu01
    Then your talking about Mitsubishi making a car that will cost around $40,000 base. And only rich boys would get them.
    BlueESV6
    I was at a dealership tonight and a salesman (if you believe him) said the 3.8 was the same engine that the Montero uses. It has a lot of torque built in at the low end of the rpm spectrum. I think he was saying 260lbs at around 1500 rpm's!!
    So basically it sounds like it really launches but can it keep up that pace or does it fall flat??? It looked all right in person. I thought it was the new Diamante when I first saw it.
    Just an update.
    MotorWeek TV tested the GTS.
    It ran a 15.3@93mph. Thats over a second faster than the 8G GTZ.
    <div class='quotetop'>QUOTE(MidNightRacing)</div><div class='quotemain'>Im waiting to spank a 9g just like i spank the 8g's :twisted: Â*:twisted: Â*:twisted:</div>
    You could hardly spank a 5G, the way you drive...
    I think me and Xska55 lost you like 5 times goin to Jerz and we were only doing 60
