nobody knows or nobody cares???? :cry:
yes it will
when is we gon be free????
$170 for a T25?
Bad idea.
small and lacks efficiency?
it comes stock on the 2g eclipse... did u see it on one of them?
as far as size, it would fit... but there are a lot more turbo's that would be better for you.
stick with a 14b or 16g. It just makes sense, seeing how thats what most 2g owners upgrade to
$170 for a t25 is expensive, you could almost buy a 16g for that. 14bs cost $100 or less...
That's why.Originally Posted by seth98esT
it *IS* cheap.. buying one from mitsu would cost you almost $1kOriginally Posted by josh_877
but.. as far as performance value... it's not worth more than $50.. and Should only be Used For breaking-in a new motor...with zero boost..
it's not A performance turbo.. and I'd only consider it for a direct replacement of stock parts.. not as a performance upgrade...
unless you plan on running 3-4Psi
