just clean/prep the surface good.. and the tape should stick... most parts are held with the double sided tape.
Hi today I received the Galant letters for the side of the front doors, does anyone knows how to place the letters if I need to use a special type of tape or glue or if I put them with the doble tape that they come although it doesnt seem it will hold them for very long?
<a href='http://ipods.freepay.com/?r=22659223' target='_blank'>http://ipods.freepay.com/?r=22659223</a>
So I should stick them with the tape that they come? It doesnt seem very strong
The OEM tape should be fine.
-MIKE.
Ya it should be fine.. if it's OEM that is.... other than that you might have to hit the dealership for it, or to autozone or pepboys..
<div class='quotetop'>QUOTE(alexx123)</div><div class='quotemain'>So I should stick them with the tape that they come? It doesnt seem very strong</div>
when i got mine the tape didnt seem very strong, but it holds!!
you can buy those letters??? i cut them out myself. remember to use rubbing alcohol on it to get the old wax off the car, cus they wont stick otherwise. and where can u buy these??
I bought mine in Ebay
how much,from who, and was the seller a good one? I want to get some more letters
I was hopin those ones on Ebay wouldnt sell :cry:
I got mine of ebay about $10 cheaper then from the dealer. I cleaned up the surface with OOPS remover and put them on, so far they are DEAD ON.
<div class='quotetop'>QUOTE(str8304)</div><div class='quotemain'>how much,from who, and was the seller a good one? Â*I want to get some more letters</div>
They were like $17, the seller was ppcproductions, he was good
