Schematics for the starter don't seem right... I may have gone retarded and read them wrong but they say the A/T has no starter relay circuit completes when you turn the key and it is in park or neutral, outside of P/N the path is broken and car won't start but not because of a relay but because of the P/N switch. The M/t is shown as having a relay that is controlled by the clutch pedal, clutch pedal switch completes the circuit alowing the relay to swap positions and supply the starter with the + side to start up.
Are you guys who swapped installing the clutch position switch or ignoring that all together?
