Open the center console, pickup the rubber insert on the bottom, take out the 2 bolts. As i remember that will allow you to remove the whole console. Then you can run wires anywhere you want to. There may also be 2 more screws under the shifter trim piece. What kind of light do you have anyway? and where are they located.
