i dont know, i just want more pix![]()
Hello everybody![]()
I'm a happy owner of 2003 Galant GTZ from Poland- JDM Style.
Here is a photo of my dashboard. Could you explain me what are those lights TCL and this Car next to it.
Yestarday I was practicing at snow 8) and TCL is of course Traction Control but what is the other. It turns on when traction should work but TCL light was also turning on sometimes. Two lights for the same system? So what is the difference?
TCL is on when you have traction control disabled.
The other light blinks when you're slipping and the TCL is working.
Disable is only possible by removing the fuse?
<div class='quotetop'>QUOTE(Michal_GTZ)</div><div class='quotemain'>Disable is only possible by removing the fuse?</div>
im pretty sure you could figure out the wiring and put in a switch somewhere.
but if its anything like the USDM galants, if u pull the fuse you lose the ABS.
