Thread: Spark Plugs Install.
Showing results 1 to 18 of 18
    Is there a tutorial on how to install em on a 8g I4 ?
    thanks.
    TGC Regular
    04-10-2004
    Brooklyn, NY
    704
    Dude you dont need a tutorial. It is so easy to change the plugs on the I4 you would'nt believe. The first time I did mine, it took me about 10 mins.
    You just need the right tools. You need a spark plug socket and a 6" extension. Remove the 2 ignition cables, then remove the 2 ignition coils to get to the other 2 plugs.
    If you can come to brooklyn, I will help you. Let me know how it goes.
    Like devgrp said, it's pretty easy.
    1) Get spark plugs for your car with the right gap. It would be smart
    to double check the gap with a gap checking tool. Any place that
    sells spark plugs would also sell the gap checker, only $1-2.
    I recommend NGK V-Power plugs, the stock type.
    2) Do one cylinder at a time, so you don't somehow put the coils/wires
    back on out of order. The coils and wires just pull out with a little
    twisting. Blast some compressed air into the tube so any dirt or
    anything in there doesn't go into the cylinder when you pull out the plug.
    3) Remove the spark plug with a spark plug socket and 6" extension.
    [a spark plug socket is just a regular socket with an o ring or something
    in it so that the spark plug stays inside the socket when you lift it out]
    You can get by without the spark plug socket if you're crafty, just use
    a regular socket and lift the plug out with some very long nose pliers
    or chopsticks or something. I believe the spark plugs are 5/8", but don't
    quote me on that.
    4) Put a little antiseize on the threads of your new plug, and a little
    dielectric grease on the wire contact point, then install it carefully
    being sure not to cross-thread. One easy way to avoid cross-threading
    is to stick a big plastic straw over the end of the plug and use that to
    get it started, then finish it off with the socket, torque to 20-25ft/lbs.
    Be careful not to get anything on the sparking end of the plug.
    If you get some dielectric grease or antiseize on it, it won't spark.
    5) Replace coil over, repeat for other 3 plugs.
    TGC Regular
    04-10-2004
    Brooklyn, NY
    704
    You dont even need the grease. When I got my denso plugs from Autozone, they already had the grease and was gapped correctly. Real simple job.
    08-01-2002
    Keokuk, IA
    8,348
    Hardest part is making sure they are all gapped correctly. Man on my Talon there isnt enough grease on the cheap autozone plugs and/or wires so its hard to pull the plug wires out. I broke one plug wire already. I hate cheap autozone crap. Their brake rotors and pads suck too...
    02-28-2005
    Metropolis
    3,540
    Quote Originally Posted by seth98esT
    NEVER. I MEAN NEVER buy any pads, drums, rotors, brakelines, struts, batteries, etc.... from Autozone. Spark plugs are cool.
    TGC Regular
    04-10-2004
    Brooklyn, NY
    704
    I got my pads from Autozone. Cost me about $30, and I had them since last summer. They just started squeaking since last week. I'm gonna change em next week.
    i got my NGK iridiums in the mail. maybe ill come down to bk...once my plugs are here.
    with the iridium plugs you don't want to regap. you might ruin the plug.
    08-01-2002
    Keokuk, IA
    8,348
    Quote Originally Posted by devgrp
    I got the cheapest rotors/pads from AutoZone on my talon. NEVER AGAIN. My gosh the squeaking never stops! I liked my brembos/axxis metal masters on the galant, they never squeaked!
    well i got my plugs and they didnt have any greese on them.
    i never seen this done so i dont wanna fuck anything up. ill come down to BK if u got a minute for me devgrp. just tell me where and when.
    oh i also ordered the magnacore wires, hopefully the combo makes my vibration and gas/miles better.
    TGC Regular
    04-10-2004
    Brooklyn, NY
    704
    Quote Originally Posted by BxGalant99
    Hey, I'm off from this weekend, so if you wanna do it then just let me know.
    Member
    04-10-2005
    Louisiana- now HTOWN
    120
    just a curious question does good plugs and magnacore wires reduce vibration n improve gas mileage??? also does good sparkplug do anything benificial for cars... sorry dont know much about these things still learning
    <span style='font-size:22pt;line-height:100%'>Geaux Tigers!!!!!!</span>
    r u free from 10 am til 2 pm on saturday ?
  15. #15
    Quote Originally Posted by wannabee
    thats what they say. this is my first car so i dont have a lot of experience either.
  16. #16
    TGC Regular
    04-10-2004
    Brooklyn, NY
    704
    Yeah, just gimme a holla
  17. #17
    GalantGuy96
    im going to make my own tutorial thread soon.
    Air freshener: 8g
    okay okay...so i stole the idea from jason...
  18. #18
