NEWBIE
sunroof adjustment (aftermkt)
Hello all.. I have an aftermarket (spoiler) sunroof, the kind the pops up and slides over the roof. It was manufactured by "Webasto, West Germany." My question is does anybody out there know how to handle the maintenance/adjustments on such sunroofs? I get excessive wind noise at highway speeds yet when you hold the button in the closed position, it is "pinched" close which forms a seal thus the noise is supressed. Thanks in advance to all subsequent replies.
I have the same type of sunroof, but mine was factory. Are you certain that yours is aftermarket?
Mine is doing the same also. Does yours make a "clicking" or "popping"
sound when you open or close it? (mine does) I found that if I open it all the way until it makes two clicking sounds then close it, it seals up OK. I think something is loose. I'm going to wait until it's a little warmer out, just in case I have to keep it offfor a day or two.
