sounds like maybe you're hitting the bumpstop (or lack of one for some reason). Take it back to the shop that did the work, if they're a decent place they should stand behind their work and take care of you.
I recently replaced my worn shocks with New stock shocks and decieded to also replace my springs with 4 new Pro Line Eibach springs.
The car lowered beautifully, but now when ever I drive over a bump I hear a loud banging sound in the rear of the car.
If the bump is driven over with passengers in the car, the shit sounds like the car is about to break.
I currently have Factory Steel wheels from a 2003 Galant size 16".
I removed the tires to see if there was any damage but all I was able to see was a small scrape on the wall where the tire is placed.
Image can be found at
http://us.f2.yahoofs.com/users/fc2c7447_m4...htKduCBBG6NCuEQ
[b]<span style='color:#800000'>1999 Galant ES Barcelona Red Pearl w/leather</span>
<span style='color:#800000'>Brembo Rotors - dimpled and slotted rotors with
Axxis pads</span>
<span style='color:#800000'>GDI Imports Reverse Indiglow EL Gauges</span>
<span style='color:#800000'>Rosin CD/DVD Head Unit with 7" Motorized LCD</span>
<span style='color:#800000'>2 SoundStream Amps for a total of 1800 watts of power</span>
<span style='color:#800000'>6 Kicker component speakers, and 1-12" Kicker Solo Baric L5</span>
<span style='color:#800000'>1Ghz PIII AutoPC to manage my MP3 playback</span>
<span style='color:#800000'>Still thinking on what's next</span>
You can check out the pics at
http://photos.yahoo.com/nene1120
Last update :2/2003
Did they remove the stock bumpstops or cut them per the spring installation directions?
<img>
did you make sure that all the nuts and bolts are torqued corectly. i had a similar problem in the front when i first installed my springs and that went away when i retorqued everything.
I had that same problem and it was the same side. The rear passenger side. It turned out to be the rubber boot. It was completely ripped, so every time I went over a bump, the spring would hit on the strut mount and make a clanking sound. I had to get another boot and that solved the problem.
