why dont u rewire them to the corners on ur headlights![]()
The fact being that my body kit is going to be on soon, I think it would be a good time to figure out what I am going to do for turn signals. There is no specific mounting point on the new fiberglass bumper so i fugure I will mount them on the side mesh, but i dont know what to use or how to mount them.
Can anyone help me?
m3 mirrors could always b an option![]()
some1 also brought up the foglight option (the person a mile away knows ur switching lanes)
but i'd jus mount them in those big sidemouths of ur kit n put a grill infront of them so u cant see them as much (if u cant wire ur sidelights as ur turnsignals) (for that clean look)
05 - Scion tC
95 - Mitsubishi Galant S
K&N FPIK Intake ; KYB GR-2s ; Eibach Pro-Kit
Currently in Project:
DOHC (i jus need a few more parts)
AT Built Tranny (just need axles)
Wire them to your corners. Its not hard and the cleanest/cheapest/easiest solution.
as said above ^ i disconnected my corner lights and made them my blinkers
i think seth might have a set of m3 mirrors for you if he still has them. might want to send him a pm
those in conjuction with the corner light rewire, and you wouldn't have any daytime visability issues
You should be able to hook them up to a relay of some sorts. Not sure how to do it, but it can be done. Mine are just a simple blinker function only for now.
i know when you hook up sidemarkers, some people hook up the positive on the sidemarker to the positive of the parking light and the negative to the positive of the blinker. so that when the parking light is on, the sidekarker is on. but when the blinkers go on, the sidemarkers blink too. that might work.
i am good at wiring and creating working circuits so i will probably make it so the corner lights work for both, i dont want too much clutter so that seems like the best thing. but i wonder if i can put a bulb like in the tail lights that have dual filaments so they can change brightness without overpowering the light overpowering= fast blowing
if you want, if i figure out the circuit i will post a wiring diagram here
where do u get the m3 mirror blinkers??? ive seen them for civics but not for my 7g..
