<div class='quotetop'>QUOTE(cdaw2001ES)</div><div class='quotemain'>I was checking this mod against my A/F meter and DMM voltage readings. It offers no chnage in A/F ration under 80% Throttle due to that being controlled by Lambda (02 sensor), I took it on the road at 4 different adjustments, between 1 turn and full out (it stops before it falls out) Â*I did not see any major diff, At stock the WOT was hitting between the R and the H on my Autometer A/F and .91~ 1.25 on my DMM, at full out and WOT I was seeing Stohic to C, and .88 ~ 1.1. Now my test was flawed in a way, as Where I was driving, I couldn't stay at WOT for more then 2~3 seconds. It does len it out a bit, but to lock it in to true constant stohic @ wot is still gonna need an afc.</div>
For those of us who don't speak AFC could you please translate that into English? Thanks in adavnce!
