<div class='quotetop'>QUOTE(lonestar22)</div><div class='quotemain'>i hav a 4g64 and i heard somewhere that without a differential your spinning one tire. well i knew this was true with rear wheel drive but do only one wheel in the front spin when the car burns out?</div>
Yes, unless you have an LSD you will do fabulous on wheel burnouts. As for which one, I'm assuming the one that has less traction will always spin...not always the same though.
