Looks hot. You should do a tutorial
I know someone else has done something similer to this, but I thought I would give it a shot and heres the half way finished product, only half way because I need to add about 14 more LED's to fill in some gaps. Keep in mind I only used 3mm LED's and I don't even know how many I used but a hell of a lot. Tell me what you all think.
yeah that does look cool, i know the 7 G has that section of light running across the middle of the trunk lid, but something like that might look different under that chrome piece above the plate on the 8G
> TGCPA - SOUTHEAST
> 1999 ES V6 (Sold 2/2011)
Yeah I was thinking about doing a Tutorial, but I need to come up with a better way to cover them other then using tape. Glad you guys like it.
<div class='quotetop'>QUOTE(glantv699)</div><div class='quotemain'>yeah that does look cool, i know the 7 G has that section of light running across the middle of the trunk lid, but something like that might look different under that chrome piece above the plate on the 8G</div>
Yeah its just as easy as using LED's like mine but facing down. I'm glad you all like it, I had a 100 red LED's and thought I should do that.
illant i think is his name. he did 3 led's though.. and using shrink wrap and black silicone caulk
<div class='quotetop'>QUOTE(Proto)</div><div class='quotemain'>illant i think is his name. he did 3 led's though.. and using shrink wrap and black silicone caulk</div>
Thats good info for me, a way for me to seal it. I'm just using clear duct tape as a temporary seal. Shrink wrap... where can I get some... lol. With that in mind, I'll make the Tutorial when I get some shirnk wrap and some black silicone.
l
I added some more LED's, but now I want to make them brighter so I'm putting resistors to every 3rd led.
<span style='color:red'><span style='font-size:25pt;line-height:100%'>And now I re-wired them so now there a little brighter, and will make them easyer to see in the day time.</span></span>
Only the LED brake light ON on the trunk.
Close up
All brake lights on. ( I know I need to change my bulbs.)
yeah, actually you probably can, you just have to drill the holes big enough to fit the bulbs inside. I just had a bunch of LED's so I just thought I would use them insted of bulbs, and I like how much faster they are at responding to the brake light.
