I think that should be enough, just strip away the interior of the trunk. maybe get the dynamat roller or when I did my rear deck I used the back of a stubby screw driver. It is to get the dynamat into the grooves and rounded edges. I also used a heat gun to heat it up a little so that it adhered a little better. I am looking to do my trunk as soon as it cools down here a bit, it is too damn hot to work on my car. Let me know if you run into any problems but it should be pretty easy.
