first of all for that bolt that you keep having to tighten, uhm i'd remove the wheel and make sure that the nut or the lug itself is not stripped. that can cause it to come loose. o yea torque it up to spec, that would make sure it won't come off if nothing else is wrong.
as for the squeeking, i'd put on maybe the stockers and see if you can still hear it, it could just be from the tires....
