you should get your alignment checked and fixed if its off, or your new tires will have the same problem
Good day all,
Finally got me 17" Mag and 215/45/R17 tyres.
Balanced done already from the shop before sending.
Spacers installed.
Now the alignment question. Me old 15" oem Mags had alignment problems. The tyres were bad on the inner side. 3 out of 4 were like these.
Will the new tyres have the same problem too?
PSI questionthe tyres wrote 44psi .
Is this too extreme folks?
at the moment its 37PSI. read on some of the posts that 35psi is enuf.
Thanks all.
<div class='quotetop'>QUOTE(pinoyesv6)</div><div class='quotemain'>you should get your alignment checked and fixed if its off, or your new tires will have the same problem</div>
ah i see Pinoyesv6... the alignment problem rests with the car not the tyres then?
also...
is 44psi too much do you think?
i don't think so... i'm running on 215/45/17's right now kumho ecsta asx tires and when i had them mounted the tire pressure was at 45 or so... it says 50 max on mine so i think it's cool.
[20:33] fenderi: did they screw up your wiper leds yet?
[20:33] lKoRTy: i dont know man
[20:33] lKoRTy: i wil see topmorrow
[20:33] lKoRTy: lol
[20:33] fenderi: hopefully they did the car a favor and chucked them
[20:34] lKoRTy: screw you
i see... mine only says 44max psi.Originally Posted by ryans99es2.4
pretty happy so far with the nankang NS II.
more info on tyre car + alignment info
http://www.bobjane.com.au/pdf/Guide_To_Tyr..._And_Safety.pdf
