the factory temp needles doesn't tell you much anyways. it just tells you when your car is cold, warmed up and overheating.
is there anyway to see what the temp needle should be at i think im running a little hotter than usuall and it getting colder oils good anitfreeze is good and ever since i put the gauges in its been off a little but i dont know how much is there any way to fix this?
any help would be greatly appreciated i searched but all i got was dont mess that up but is there any way to double check yourself
I have a salvage galant with grey interior and white outside very little body damage just little dents. I think it has a locked motor because it ticks and it has a new starter. It is a total part out and I have parts from many other galants in the past. Pm me if you need any parts and I will let you know if I have them or not.
im glad u responded
i checked my oil and antifreeze and it ok is there anyway to see if my car is running to hot or am i just strugglin
You could just get an aftermarket temp guage. When I took off my needles I rememberd where my car would idle at and turned my car on with the guage cluster in and just the clear face off and put the needle on when my car was idleing, and I rememberd where my temp was when I drove it around the whole day.
