Originally Posted by
j686m
so its actually the a/c high side(smaller) line thats in the way of the turbo?
if thats all it is then i could chop the hard line and hose off and have AN fittings welded to compressor fittings and connect it with braided steel hose. i mean that stuff is good for 1000 psi and the most that high side line will ever see is aroun 200-300
nah the solution is much easier than that. besides flare fittings aren't designed for that application.
just go to a place that makes a/c lines
there is a place in louisville i took a busted hose from my sisters car to .
they created a whole new line and welded my fittings to it.
only cost me about 40 bucks
if you already have the fittings they could make yopu a new one easy. or create new fittings that redirect the line. its not that complicated. just be sure to get your refrigerant evacuated the proper way.
