the first 7 might fit.
the last one defitnely won't fit.
i say might just because you didn't provide us with details such as bolt pattern and offset which are critical when trying to figure out if a wheel will fit or not.
hey i was wondering if theses rims fit my 2001 g im thinking of geting them the company name ICW rim name 925 vapor
my queston will if fit or not becuse inedd new tires and don'yt wann buy tires and no rims and which size is best for the car where it don't shake and rides perferct
15x7 4x100 +38
15x7 4x114.3 +38
15x7 5x100 +38
15x7 5x114.3 +38
16x7 4x100 +40
16x7 4x114.3 +40
16x7 5x100 +40
16x7 5x114.3 +40
17x7 4x100 +42
17x7 4x114.3 +42
17x7 5x100 +42
17x7 5x114.3 +42
18x7.5 4x100 +42
18x7.5 4x114.3 +42
18x7.5 5x100 +42
18x7.5 5x114.3 +42
The Bolt Pattern Measurements are from the center of a bolt hole to the next holes center is 2 1/2 inches. If you skip a hole the measurement is 4 1/8 inches from center to center. there 16 + 8 i think offset is 45
this is how you measure the bolt pattern for a 5 lug wheel
im buying off the net
well without the right info i can't really tell you if its gonna fit.
and having the measurements in milimeters would be better too. for example, many toyotas have a 5x100mm bolt pattern, some of the audi's have a 5x112mm bolt pattern and the mitsu has a 5x114.3mm bolt pattern. yea 2.3mm between the mitsu bolt pattern and the audi bolt pattern might not seem like alot but its enough to make the wheel not fit.
ok i got this from the seller
5X112 Bolt Pattern by the measurements of the bolt holes. The hole in the center of the wheel is 2 1/8 with a gold ring spacer that could come out to be a 2 5/8 hole.
<div class='quotetop'>QUOTE(redgalant1)</div><div class='quotemain'>ok i got this from the seller
5X112 Bolt Pattern by the measurements of the bolt holes. The hole in the center of the wheel is 2 1/8 with a gold ring spacer that could come out to be a 2 5/8 hole.</div>
<div class='quotetop'>QUOTE(pinoyesv6)</div><div class='quotemain'>some of the audi's have a 5x112mm bolt pattern and the mitsu has a 5x114.3mm bolt pattern. yea 2.3mm between the mitsu bolt pattern and the audi bolt pattern might not seem like alot but its enough to make the wheel not fit.</div>
that a no
[quote=pinoyesv6][quote=pinoyesv6]some of the audi's have a 5x112mm bolt pattern and the mitsu has a 5x114.3mm bolt pattern. yea 2.3mm between the mitsu bolt pattern and the audi bolt pattern might not seem like alot but <span style='color:red'><span style='font-size:25pt;line-height:100%'>its enough to make the wheel not fit</span></span>Originally Posted by redgalant1
