https://www.thegalantcenter.org/viewt...s+irotors+axxis
irotors are great. if you order from them(which you should),
tell them john turnmire sent you.
you will like them. i used the ceramic pads but metal master are good too if you want to save cash. both have great bite.
be sure to flush your old dirty spongy brake fluid out with some fresh DOT 4 fluid when you change your rotors. wouldn't want to ruin a perfectly good set now would you?
and use moly brake lube for your slide and guide pins.
