there are 2 bolts on each coil pack that hold the two on the valve cover and the other two cylinders will just have plug wires off of the coil packs. remove the plug wires and then remove the connectors on the coil packs. next, remove the bolts on the coil packs and pull them straight up. then all you have to do is get out your spark plug socket and ratchet them out and reverse the instuctions to put it back together.
