Thread: Ignition problem
Showing results 1 to 3 of 3
    japs
    Ignition problem
    I have a Galant 2.0 SOHC 16 valve from the year 1993/1994. I have a ignition problem and i could fix it if I only had the electrical schemes for checking the whole engine. Does someone have them or can someone suggest a place i can get them Please help me!!!! What I basicli need is a 7G repair manual.
    Tazz2000
    There is no need for multiple posts on the same topic.
    *deleted second topic*
    Experienced TGC Member
    07-31-2002
    San Antonio, Tex-Mex
    1,413
    Best thing you could do is go buy a Chilton's repair manual from you local NAPA or what have you. It is my Holy Bible for my car
    [b]<span style='color:blue'>Wes</span>
    The true path to enlightenment is Here
    <-Check it out Maz
    My 7g
    [b]<span style='color:darkred'>ClubTGC Shidoshi-Kai Fellowship</span>
