Did you get your tails with the JDM harness?
If you didn't get a harness, just pick up an 1157 socket from a local auto shop if you don't have the harness and splice it into your existing harness, then dremel out the hold a bit to get the socket to fit.
I used this one:
I'll try and find my JDM tails install tutorial and repost it as the original was lost in the Galant Forums switchover.
