I havent seen the I4 headers but based on the V6 headers here's my suspicion. You have a Fed spec car. Sounds like the headers you have are just fine. You will have to relocate the O2 sensor . As far as the bolt up goes, you're right. The headers bolt on to the flex pipe. However, if the I4 is designed like the V6 your cat doesn't have a flange on the front. So what you'll have to do is cut your cat at the front and weld a flange on it. Then match that flange up to the other end of the flex pipe and you're golden.
Just to be sure about the O2 sensor, email David Thomas at RPW or Matt at Vision Imports. They're both experts in their product. Let me know if you need addresses
