i was thinking the red w/ black stripe is the low and the solid red is the high. but i can't remember exactly. i just rewired my lights 2 weeks agoOriginally Posted by ericbla03
Hey, anyone know the wire colors for the highs and lows (i assume ground is the black one). I searched and all i could find was the bulb list.
Thanks
ummm.. the wires in this harness are blue, red, and black. Maybe its a different year than yours.Originally Posted by DOHCstunr
blue is high beam, red is low, black is ground. hint my tutorial
https://www.thegalantcenter.org/viewt...pic.php?t=41406
DOHCstunr and proto are both right.
if you look at the wiring from the headlight proto is right. now if you look at the wiring going to the headlight, DOHCstunr is semi right. its red with blue stripe not black stripe.
OK, i see. Im looking at the headlight harness that is actually attatched to the bulbs. So proto had what i was looking for. Thanks guys.
