dude screw it all.Originally Posted by Mante
just tap the fuel pump drive signal wire off the ecu, and use it to trigger a fuel pump rewire.
send some beefy power wire to the pump and give it a nice fat ground, and you'll flow more fuel at higher rpms cause it will be able to supply the pump w/o voltage drop.
or did you do that already?
think it costs about 15-20 bucks with some home depot wire, and a Walmart relay.
