use that epoxy you used on those mirrors or untighten the support bolts and push the bumper up.
this is the pasenger side
i can also fit my finger inbetween the headlight and the bumper!
any ideas on how i can fix this?
R.I.P. My fellow Galant owner. May God be with you and your family.
<div class='quotetop'>QUOTE(Proto)</div><div class='quotemain'>use that epoxy you used on those mirrors or untighten the support bolts and push the bumper up.</div>
epoxy... Ha Ha Ha 8) it's still holding up i don't wiggle or anything... how can i get to those support bolts thanks...
<div class='quotetop'>QUOTE(The F.B.I)</div><div class='quotemain'><div class='quotetop'>QUOTE(Proto)</div><div class='quotemain'>use that epoxy you used on those mirrors or untighten the support bolts and push the bumper up.</div>
epoxy... Ha Ha Ha 8) it's still holding up i don't wiggle or anything... how can i get to those support bolts thanks...</div>
12" extension bar (i dont know if its different on the 8g)
i had the same prblem last month.. my bumber came off cause my wife hit something.. i put it back on but had a little gap.. i figured it's just not tight enough but when i checked, the screw was all the way in already.. what i did was i put something below my bumber to hold it up to flush with the fender while i epoxed it. it looks pretty good noe.
i'll check it out in the morn i hope its just the bolts im not tryna epoxy it since im getting a kit soon, it just bugs me that its there and im tryna roll to MOD with out anything falling off haha
a dishonest seller huh????
drop the fender liner and you can easily get to that bolt you need to tighten.
