Thread: **UPDATE** 10/04/03 Parts list for drum to disc conversion
Page 2 of 2 FirstFirst 12
Showing results 21 to 27 of 27
  1. #21
    ....too small
  2. #22
    escoson
    <div class='quotetop'>QUOTE(Auto-9)</div><div class='quotemain'>Since I already have disc brakes I wanted to do the 2 piston conversion from the older GTs. Might help with the weak braking. Or I might as well look for a 4 piston system that fits in a 16 inch wheel...good luck to me.</div>
    aem makes a 4 piston setup
  3. #23
    Team TGCLV
  4. #24
    Team TGCLV
  5. #25
    sorry for the pictures being so large
    Team TGCLV
  6. #26
    Russian7G
    Does anybody have the list for the 7G? I've already figured out that the hubs are the same, so I need 94GS calipers (the whole assembly), rear rotors.. what else? what parts do I need for the parking brake? I use it a lot!
  7. #27
    lemonnamedsteve
    can someone take those parts lists off of that site...so we can actualy see them? cause that would be awsome
