what kinda lug wrench are u using? i hope ur not using a torque wrench. that can ruin the wrench. i hope u aren't using the stock lug wrench either, that won't help u at all. if you can't find a bigger lug wrench (i like my t-bar) try slipping a pipe over the handle of the lug wrench for more mechanical advantage. but yea be careful you don't want to break a lug or something. if you can try to get a hold of an air gun. walmart has some for like 20 dollars that is pretty strong and uses ur car's dc power. uhm a small shop should have an air gun blah blah blah...just amek sure its torqued right and u ahve something good to remove the lugs with
