I have never did it..but I believe I have read other member taking our the amber lens with a screwdriver. Basically breaking the amber lens and getting the broken pieces out.
Hi, I wanna ask, if its possible to put out the yellow thing, plastic inside the lamp, that make the color of turn light. It is simillar to front corners? Thanks for answer.
www.mitsubishiklub.cz
Dream, as if you live for ever, live as if you will die today, the choice is yours.
Thanks, are here any photos? I was looking for it, but I havent found anything.
Yep that was me. But once you've cracked it with the screw driver, get some needle nose pliers grab a piece of the plastic and twist. It should break off in big chunks
You could do that, or you could actually de-construct them the same way you'd pull apart your headlights. The piece is held in there simply by screws. That's what I did when I was making my reversed-LED taillights that turned out to be a huge failure... =(
BMW owner. Galant fanatic.
