Originally Posted by
DOHCstunr
depends on your fuel system, and the strength of your bottom end.
are you still on stock rods?
how large are your injectors.
and what kind of power do you want to have?
with a 2.4 just about any mid-large turbo will spool just right for you.
20g, 50trim(if you want to run between 18 and 30 psi), vtrim(if you want to run under 20psi and make big power)
evo 16g is a great turbo but on a 2.4 its going to spool so quick you will hate it(on a fwd anyways)
i'd run nothing smaller than a 18g.
you are really going to want something with at least a td06h turbine wheel.
but again. you are limited by your feul system, and how much flow you have in your injectors.
need more info
