Thread: 2003 Outlander NON MIVEC Engine
Page 1 of 2 12 LastLast
Showing results 1 to 20 of 31
    I was looking and searching through several threads/post due to the fact that my intake manifold off my 1999 4G64 decided to crack once again (2nd Time replacing). So after looking at the threads, I indeed came to the conclusion that the intake manifold off the 2003 4G64 Mitsubishi Outlander NON MIVEC will swap right in to our 8g 4G64.
    Parts that will be needed for the swap are:
    Intake Manifold
    Throttle Body
    Throttle Cable
    Throttle Position Sensor
    Fuel Rail
    Fuel Pressure Regulator
    Fuel Injectors
    EGR and all sensors attached to the manifold
    The install/swap is pretty straight foward and all you need to modify is the wiring of the sensors by extending the wiring to fit the manifold/connections. The benefits of installing this intkae manifold is that it looks alot strong and sturdy compraed to the OEM intake manifolds on our cars and also performance wise the openings are 60mm compared to 54mm that are on our 8g's. here are pics of the intake manifold installed on our cars:
    My question is this, since we are able to swap the intake manifold from the Outlander to our cars and it has a 60mm opening. Does that mean or do you think it has bigger cams that we can swap into our cars to give us better performance?
    I know RPW makes camshafts for our cars and they are highly modified camshafts but financial situations do not allow me to purchase any of these right now.
    Here is the website where the cams can be purchase: Click here
    Anyone have any information or comments on this?
    12-17-2004
    Louisville, KY
    4,327
    Quote Originally Posted by Three O Five 8g
    You weren't the first.
    the intake manifold is the only difference.
    although there might be other slight bolt on variances between the engine bays.
    the motor and all of its components are identicle between the outlander eclipse and the galant.
    cams will be identical.
    Experienced TGC Member DryBear's Avatar
    11-05-2003
    San Francisco Bay Area
    1,517
    Here's a tutorial of the swap by Underated/4G64T:
    http://www.galantforums.com/downloads/Gala...anifoldSwap.pdf
    I can those pics without my glasses. wow!
    Supposedly, Mitsu has changed part number for the galant intake manifold. The new part number cross references the 03 outlander manifold. Got this info from the dealer, and also from mitsubishiparts.com. You might want to confirm this before buying. According to dealer everything should swap over with no mods. Not sure about that last statement though.
    11-05-2003
    1,517
    Again, this has already been successfully done on at least 2 8G Galants, one of them even being turboed (the author of the tutorial I posted above).
    08-08-2004
    Las Vegas
    2,098
    haha thanks Len for posting that i havent been on the boards for awhile
    but the swap is very easy... there are a few other things you need that are not on that list on the first post... and some that are there that you dont need....
    you dont need the fpr, fuel rail or injectors
    but you do need the manifold support bracket, and you do need to bend you stock dipstick tube and you do need the outlander throttle cable or you can place washers under the gas peddel to bring it out farther... if you dont do this the throttle will only open 75%
    als you have to swap the 2 outer wire on the throttle position sensor clip or you will get incorrect readings
    Read the tutorial i covered everything in it with pictures
    Thanks for all your help and all your info...
    One question though... my car is dropped and I have a body kit and all.. Do I really need to lift up the car with jacks and all that to work on the manifold or can I do all this work from above only?
    Well, I recently replaced mine with the stock manifold and I didn't have to jack it up. But I didn't need to remove the bracket holding the manifold.
    08-08-2004
    Las Vegas
    2,098
    its possible to do it with out jacking up the car swivel (sp) joints for your sockets will make it easier tho
    Experienced TGC Member Kalamidad's Avatar
    11-24-2002
    Originally TGCNY, Now TGCTX
    1,781
    wow, that's a great tutorial underated. I just broke my intake mani again. I'm going to the Junk yard tomorrow. I'll try to get my hands the Outlander mani. I've done the OEM swap before.
    -Pedro
    07-31-2002
    Bronx NYC (reppin)
    3,489
    Ya its worth a shot instead of throwing your money away for another flimsy manifold.
    Drive It Like You Stole It!
    7G Erubini Body Kit for sale
    11-24-2002
    1,781
    I'm reading the tutorial now. It's really good man. I'll try to take some pictures so you can add them.
    -Pedro
    Quote Originally Posted by Kalamidad
    Ummm, I am going to repeat myself again. Supposedly the design has changed for the intake manifold. The new part number cross references the outlander manifold. The old galant manifold known to crack is no longer manufactured. The dealership told me this recently, and he said the new design that cross references the outlander will need no modifications. He stated everything will swap over. You might want to check on this before buying from a junkyard.
  15. #15
    11-24-2002
    1,781
    well, this manifold that broke today was purchased that the dealership in FEB of this year. So i think i still wanna try my luck with the outlander from the junk yard.
    thanks though.
    -Pedro
  16. #16
    thanks though.
    The manufacturer's design was changed within the last 2-3 months. Just my 2 cents, it won't hurt anything to check.
  17. #17
    11-24-2002
    1,781
    Quote Originally Posted by neepar
    oh ok. Thanks. That changes things. They should make it a recall. Bastards!!!!
    I'll look into it. But still, an outlander from the junkyard would cost me less. I won't be able to find the redesigned Mani in the junkyard since the 8G hasn't been produced for over two years now.
    -Pedro
  18. #18
    11-24-2002
    1,781
    i was the the mitsu dealership earlier this week picking up the gasket seals. The mitsu tech had no idea what i was talking about when i asked him about the Manifolds being crossreferenced. i didn't spect much more from them...
    -Pedro
  19. #19
    08-23-2004
    Chaska, Minnesota
    1,370
    im selling the outlander manifold.
    https://www.thegalantcenter.org/index...mp;hl=outlander
  20. #20
    08-08-2004
    Las Vegas
    2,098
    how did the swap go Kalamidad?
