good luck
tinting my tail lights today guys...their the GTS version not the es...im guna take em off clean em and spray em...ill have pics up in a bit when im done spraying...ima clear coat them after so ill have the finished result up tommorow...
AFTER ALMOST 3 DAYS LOL IVE DONE IT...WELL ATLEAST HALF OF IT
IVE BEEN GETTN HOME LATE FROM SKOOL, WORKING, HAVING TO PUT THE TAILS BAK ON AND OFF WHHILE IN PROGRESS...I WAS ONLY ABLE TO COMPLETE ONEOF THE TWO...LOL
THESE ARE PICS IVE TAKEN AFTER WAXING IT
I PROMISE GUYS AS SOON I FINISH THE OTHER ILL HAVE DAY AND NIGHT PICS UP...
cool hopefully they will come out good
so far so good!!!
can said only use 2-3 coats...i used almost a whole can
heres what i got so far...
im hoping that when i put the clear coat on it doesnt make it even darker!!
ive had problems before with certain paint an clear coat reacting this way, but well see...ill have the finished result tommorow...i gota clear coat them in lik 6 hours, put em on before i goto school and then ill have the pics for u guys!
FLASH WITH LIGHT ABOVE
LIGHT ABOVE WITHOUT FLASH
CLOSE UP WITH FLASH
CLOSE UP WITH OUT FLASH
STANDING UP WITHOUT FLASH
i thought about doing that..all it is is 2 small screws and the glue...
it'll shine right through, don't worry too much
well just about finishing up...its dried...ive wet sanded it with my friend with 600 grit...wulda used 800 but they didnt have it, let it soak for 15 then sanded em down lghtly. my friends helping me polish compound them to get the scratched out an then ima out the clear coat on...3 coats and wet sanding in b/t each coat...
no problem...
ran into alil bit of a problem with orange peel showing so i scraped one and am in the middle of painting it...guna be a bitch to try to match each other now lol...should have pics tonight of what it looks lik on the car at night..ill keep u guys updayted
looks hot man.. cant wait for the final pic
LEFT ONE CAME OUT MINT...THE RIGHT HAS TO BE REDONE...I GTOTA ORDER MORE SPRAY SO IM GOING TO LEAVE THIS AS IS . WHAT DO YOU GUYS THINK?
Looks good
Back from the dead!!!
