I believe only 3g eclipse shocks work on your 01 gtz
does 95-99 eclipse kyb agx, fit on a 01 gtz?
thanks for the help guys, and for the record i did search and i couldnt find anything on it, and i need to know before the auction ends.
2000 Galant ES = Daily Driver
thank you so much!
00-05Originally Posted by mrjaydeeone
are the eclipse ones identical to the galant ones? because i heard someone say that the eclipse ones wear out faster or somthing on the galant and you should spend the extra money to get the galant ones, is this true?
The struts are the same one won't wear quicker than the other.Originally Posted by dknight3
I was lookin at gettin some off a 00-05 eclipse. But why are the part numbers different for the struts if they are the same?
Like kyb gr-2 rear for galant=341293, and eclipse=341164
You would think they would be the same part number if they were identical right?
i just today put in springs for a 01 eclipse eibach think they 1.5-1.6 fit fine not as low as i thought it was goin to be,but there is no more body roll and its a night and day difference in handling.
The rears will but not the fronts.
So the AGX's for the 3G will work for our 8g's???????? FML i just bought a set of GR-2's!!!!!!!!!!!!!!
1999 North Star White V6 8G
2003 Yamaha R6
2008 Lancer Evolution X
The Original FACTION from the BGR Days
First Founder of TGC Florida 2002-2005
