Thread: 7G Auto -> 5spd conversion...
Page 5 of 5 FirstFirst 12345
Showing results 81 to 92 of 92
  1. #81
    12-17-2002
    Sherman Oaks, California
    4,304
    bastards!
    http://socallifestyle.com/
    1994 Galant GS 5spd
  2. #82
    Ok figured out what all i need goin to need to grab from pull a part. Goin to try and grab it all out the same eclipse.
  3. #83
    08-01-2002
    Keokuk, IA
    8,347
    Dude, just read the tutorial.
  4. #84
    Experienced TGC Member Blue Ice's Avatar
    07-31-2002
    Kansas City, MO
    1,244
    Quote Originally Posted by seth98esT
    Impact gun is a must. Unless you put the diff carefully in a vice and have some muscles and a breaker bar.
    I had an impact gun too. those eight bolts came of in a whtwhtwhtwhtwhtwizzzzzzzzzzzzzzzz 8)
  5. #85
    07-31-2002
    Bronx NYC (reppin)
    3,489
    I was trying to decide whether i should get the OBX, SB, or Phantom grip. Any input on these things?
    Drive It Like You Stole It!
    7G Erubini Body Kit for sale
  6. #86
    05-25-2006
    New York City
    1,028
    slowboy or extremepsi one. They are made by the same company. The phantom grip has been known to fail from members of dsmtuners.
    2000 Galant ES = Daily Driver
  7. #87
    07-31-2002
    Bronx NYC (reppin)
    3,489
    so i guess the phantom grip is out of my choices eh.
  8. #88
    05-25-2006
    New York City
    1,028
    Quote Originally Posted by bronxbombr
    The phantom grip unit is also pricy compaired to the slowboy and extremepsi units.
  9. #89
    12-17-2002
    4,304
    they're all the same....essentially. i've heard of the phantom grip branded one failing here and there also.....havn't heard anything about the SBR one failing....mine's still kosher (knock on wood) since i put it in 8 months ago
    1994 Galant GS 5spd
  10. #90
    05-25-2006
    New York City
    1,028
    Thought I might add this since people are having problems when using old shift balls and forks. If your shift fork doesn't look like this you need to adjust it with shims or you will have problems with your clutch.
    and this is the pic to adjust the pedal
  11. #91
    3dmnbrand
    wut i did was go thru the p/n switch. you can permanently set the p/n switch to either park or neutral. this eliminates the need for a relay or clutch switch. i was even able to wire up the reverse light on the cluster when in reverse. just remember to replace the fuse with a higher amp. or it will just keep blowing!!! :lol:
  12. #92
    07-31-2002
    Bronx NYC (reppin)
    3,489
    Quote Originally Posted by 3dmnbrand
    Never heard of changing with a higher amp fuse before, if your fuse keep blowing then theres a problem. I never had that happen before. Nor did i need to replace anything electrical with my swap.
