Thread: OEM Suspension
Showing results 1 to 4 of 4
    OEM Suspension
    I was just wondering if anyone knows where I can find a full, rear, OEM ride height, suspension kit for a 90 GSX. I can't find OEM parts anywhere, only lowering kits, and the car is lowered now, which I would rather it wasn't. I already have front struts, but the rear components the company sent me didn't come close to fitting (I would guess they are for a rear linked suspension) and the company went belly up about a month after the parts came in (aka a week before I got the chance to fit them). Any info would be a huge help.
    1990 Galant GSX: HKS Super flow, front strut bar, KYB coil overs, UR underdrive crank pulley, Greddy Kevlar Timing belt, Revolution muffler, custom grounds, Center Force clutch, Fidanza flywheel, Pace setter header, 4 wheel cross drilled rotors
    Thanks, that's exactly what I've been looking for.
    07-20-2003
    Orlando, FL
    3,168
    Stock 1g AWD suspension will bolt up to the E38 6g Galant....a cheaper alternative is some locally upgraded their 1g AWD suspension.
