does your key work in the passenger side door jeffylou?
I sell mitsu too and i can say that 99+ all have keyless entry except for de's until 04 when all galants came with keyless entry..
2011 Camry- 202 miles- just picked up 9/10/10
2008 Pontiac G6- 26,065 miles- traded in
1999 Galant ES- 91,846 miles- long gone
no. the 2k2+ doesn't even have a keyhole. if your key doesn't work then it probably means that either its the wrong key or something is broke.Originally Posted by cdipier2
ok i will check it outOriginally Posted by pinoyesv6
ps i got my keyless entry remote today and it works great! i just wish i knew how to make the horn honk too
you have to press the unlock twice in order for it to unlock all doors. If you just want the driver door unlocked then press it once.. for all doors press twice.
The horn chirp feature can be activated or deactivated by performing the following steps while the key is removed from the ignition cylinder.
1 - Press and hold the Lock button on the transmitter for between 4 and 10 seconds.
2 - While the Lock button is being pressed, press the Unlock button.
3 - Release both buttons.
i keep trying and i cant get the horn chirp to work. i guess i will try again tomorrow
i keep following the instructions for the horn chirp but i cant get it to work :evil:
still nothing. could there possibly be something wrong with the transmitter or the keyless system itself?
same here I got a 99 es and It wont chirp.
8G 4 life!
Mods: CAI,Grounding wires, CCorners, Shaved, 3G STB. AGX/Teins, Addco bar, OZ F1 wheels And well maintained : )
does your turn signals blink twice for lock but once for unlock? thats what mine does
