yea i dont see why not , just tap into the trunk light i did that with a 12" blue neon in mine
I wanna light up my trunk a little better cuz the stock like just sucks. I was looking on ebay and i found 25lef LED strips.
http://cgi.ebay.com/25-LED-Light-Str...QQcmdZViewItem
I was wondering if i can hook that up to that stock wiring on the trunk light and use that as my trunk light?
00 Galant ES Turbo/5-Speed
13 GTR
Yep. Any 12V source will do great. You can tap into the existing wiring or just remove and replace it.
8G Galant GTZ-juiced, 275 hp
1G Eclipse GSX-pushin 400 whp-09/22/06 12.33 @ 113mph
The best of both worlds...
Good question, last week I extended the wires that goes to the trunk light and conected them to a 1157 sockets and used my 32 Leds bulb but they didn't work, then I put the regular 1157 bulb in the socket and they worked fine (the 32 led's are in working condition). I don't know why it was able to turn on the regular bulb but not the LED's?
So if i could do that, i am sure i can get another one of those strips and put in in the rear (backseat up above) for interior lights. I could prolly just tap into the dome light wire harness.
leds draw very little power so you should be fine.
if you blow a fuse, first make sure everything is wired up, and then if it still blows a fuse, then you probably need to get a relay and run a power wire. especially with that dome light, i've blown so many fuses cuz of that light.
LOL I hear you. I have blown that fuse under the hood that ties into the radio, door locks and all that other crap. It scared the shit out of me lol. What kind of realay? SPST? How would i wire it up?Originally Posted by pinoyesv6
85-->groud
30---> New power feed
86--> original positive from dome light?
87--> to new led strip?
if you're gonna do the dome light, the negative switched from the dome should be the trigger. if u tap the positive, the led strip will never turn off
ok so it should be:
85-->new power 12V line
30-->GRND
86-->GRND trigger from original dome harness
87-->GRND out to new led strip?
Where does the led strip get the 12V power from?
Well if it's a negative switch feed, then just any existing 12v + constant power source will do
Alternatively, you could just tap into the door switches, thats a far easier option, that what I did for my interior LED's. For the trunk I just tapped off the original light
the way i had mine wired up was
30 - + 12v power wire
85 - + 12v power wire
86 - switched ground from dome
87 - + 12v to the light
SO i would have to run 2 new power feeds to the relay?Originally Posted by pinoyesv6
my friend did it in his lancer.. it'll work fine
LED Modd: [email protected]
30 and 85 can share.Originally Posted by Cheekz185
Thanks Allan!Originally Posted by pinoyesv6
