Get rid of that FMU for starters. What fuel pump are you using? Post your setup so we can help you better.
And you cant swap to 1g/2g ECU unless you swap to a DOHC head and CAS/Coilpack setup.
And you 94 has 3 ECU connectors as its OBDI, its similar to a 1g ECU. If you want an easy way to tun, try to find a 95 EPROM ECU and contact Jeff at www.dsmchips.com and see if he can make an EPROM chip for you that will have better fuel trims, timing maps, fuelcut delete, stutterbox, just about anything you can think of.
