what year is your car? in the 99-01 models with the L shaped fuse boxes, the relay is in the corner on the top right when standing in front of the car. if you are standing on the side, it will be on the bottom right.
Hey guys,
I posted some time ago problem i was having with my horn, its gets stuck, and keeps blowing all the time.
I was advised to replace horn relay, to see if it helps. I got the relay, but have no clue where it goes.
I looked in engine compartment, and the manual, and there isnt horn relay relay listed.
Does anyone have any idea?any suggestions?
Thanks
its 2000 es, 4 cyl.
also, the relay i got, in size its smaller then the ones in the car arleady, connectors are the same.
why isnt horn relay listed in the manual?
Manual probably doesn't say it because Quicksilver wrote it..
:smt005
thanks dude.
I exchanged the relays, and still same shit....my horn wont stop blowing. when i bang it on the horn/airbag, it stops for a minute, then it goes off byitself again.
This is really annoying the shit out of me
Probably has something to do with the horn button then... Or faulty wiring.. I would take apart the air bag unit... ONLY do it if you know how to properly take it apart..
unfortunately i dont. i see that you're located in NJ, so am I,in Jersey city.
Would you know any honests mechanics, or places I can take my mitsubishi, and have this problem looked at?
thanks Jeffy
My dealership'll git r done.. Just pricey... cause you know labor... But I think anywhere it'll be pricey..
replace the airbag.Originally Posted by willieB
i just saw airbag for my galant on ebay.Would you guys recomend buying used one, and replacing it, so i can finally get my freaking horn to work
