Is your radiator cap rated at the right psi? and is it leaking from anywhere else? I had a problem with it leaking into my overflow and noticed that my cap busted replaced it and fixed the problem?
Cause i have replace my whole system so far replaced the radiator cap, radiator hoses, and thermostat, and its either the thermostat or the radiator cap....what happens when you turn on the heater?
