Replacing your camshaft is easy...only if you know what you are doing and doing it right. I have talked to Vision Imports and the camshafts are designed for 3 stages depending what you are looking for in performance output. I suggest to have the camshafts installed by a professional. The camshaft keeps valvetrain parts working together so the air/fuel mixture enters and exits the cylinders on que. If incorrectly install the camshaft...you will ruin all those related parts or poor performance from your motor. I should have a tutorial sometime soon...since Vision Imports has my car as a test car for any related galant performance parts.
