Check the fuses under the hood. There's a yellow fuse holder that contains two fuses. One or both of them is blown. I'm gonna start charging a dollar for every time I have to write this answer.
Maybe we should make a tutorial for installing electrical devices in your car. Step 1: Disconnect the battery. Step 2: If you don't disconnect the battery and something doesn't work when you get done, go to TGC and do a search.
