it's been thought of but nobody is sure if the 8g firewall is structurally capable of being an anchor point for bracing.Originally Posted by 6G72gearhead
I didnt think of that, I know the firewall is extended on the eclipse. Would there be any method for ridgedly making an extention bracket of sorts.
www.gooichimotorsports.com
It depends on how much the strut towers flex, I might have a solution to figuring this out. But I would mount it to the seem on the firewall that should be a strong point.
My Idea to see how much they flex. drill a piece of sheet metal to fit under one of the bolts on either strut tower. Connect a rod on either side, pvc tubing would work to. then with the smaller rods attatched to the strut towers, connect them with a larger tube that allows the rods to telescope inside of it. Take and secure the larger tube to something that wont allow it to move at all, as any movement of this piece will flaw the results. Now on the small rods mark a ring all the way around where the larger tube starts. then get two markers and secure them on the larger tube with the tip of the marker riding on the small rod, then with a different colored marker, mark a ring where the marker tip rides. Do this on both sides. Then go drive the piss out of it with a full tank of gas and then look at the results.
Think of what I have done as a dampener. With the dampener in its still position, we have marked where the piston shaft is in relation to the outer dampener tube, also we have a marker riding on the piston shaft, marking its up and down traval, we also have a mark where the marker is placed while at rest.
Now we would know how far the strut towers flex, and can then make a more educated discision as to whether or not the firewall can hold up.
- Megan Racing Full Damper Coilovers
6 clicks in the front
9 in the back
- RRE Front Strut Tower Brace
- 18" Falken Koblenz wrapped in Bridgestone Potenza 225/40/18
Galant: 1994 VR-4 V6 TT
Springs: TEIN Coilovers with Dampening kit
Wheels: 17" TSW Evo R (Can't remember the exact size)
Tires: 215/45/R17's Bridgestone MY01
Other: Cusco Front Strut Brace
Compared to the standard setup, I found the suspension to ride so much smoother.... cornering is a breeze now and stopping distance has decreased.
All an all, the TEIN setup is the best I have come across for the Galant. I used to work for mitsubishi, and most of the other setups I came across were far too hard and the car jumped all over the road.
I'm looking into a camber kit for the car in the coming months, so I'll keep you posted
1995 FTO - V6 Mivec 200hp
2000 Galant LS
OEM everything with the exception of:
Megan Racing 3G eclipse front upper strutbar.
eBay rear lower tiebar.
(dry months) Monderra 20" steel/chrome Blackhawk wheels on Nitto NT-555 Z rated tires (225/35ZR20 90W).
(wet months) 5Zigen 18" alloy Super Six wheels on Nitto NT-SN1 winter rated tires (225/40R18 92V).
Worlds better than 100% OEM already. I'm learning to love my 5Zigens over the bigger and heaver Monderras. I'm thinking about switching to 18" alloy wheels all the time on the road and just put the chrome on for shows and such. The NT-555 tires are the coolest tires I've ever had the pleasure to drive on. They stick when you want them to and seem frictionless when you don't.
Next upgrade is either going to be the D3 chassis stiffening kit or Tein Superstreet dampers with the EDFC. Thinking I need to replace my strutbar with the Tein/Carbing one with the master brake cylinder stopper.
3 300 lb chicks at the rear, two giant balls in the front.. got me 2" front 1" back.
Year: 2000 Galant 2.4L
Megan Racing
KYB-GR-2
SPC camber kit
3G Eclipse rims 17x8 (i'm not sure about the width)
205/40 R17's
3G strut bar, rolled rear fender
Everything I've done to the car so far seems to being working out real good. The springs and struts give the car a good ride. Not too stiff, but not too bouncy either.
The 2G shall have the following:
- Eibach Prokit
- Tokico Illumina Shocks&Struts
- DC Sports CS2 Front and Rear Strut Bars
- RM Rear Sway Bar
looking into under body braces also.
lmfao :DOriginally Posted by milo111000
2000 Galant ES = Daily Driver
hey could anyone tell meany sites to get affordable but good struts/shocks?
02' Galant ES i4
Tien S-tech springs
KYB GR-2's
93' Probe GT STB
Ingalls Camber Kit
18x8 5Zigen 5ZR 2 piece 225/40/18 Offset is from a 91 supra, probably a 38 maybe, not sure
Not a bad setup, I think the Tein's are a lil mushy, Planning on ditching the whole setup and running Tein Basics.
Zigen look fine, but im searching for some SSR GP-0 Evolutions. If I can find them, im buying them.
1999 ES V6 Galant
Sprint Lowering Springs
KYB AGX Shocks/Struts (set on 2 all around)
Freedom Design Strut Tower Brace
18 x 7" Finn Racing Wheels with Kumho Ecsta 711 Tires
The drop is amazing thus far, the springs are rated to -1.8 for the front and rear. I think I got way more in the front. 2 finger gap in the front and 1.5 finger gap in the rear well.
Handling is sharp and the ride is a little rougher, but the tires stay planted on the road. I am quite pleased with the setup thus far, I need to get an alignment probably, although it really looks like not much changed.
> TGCPA - SOUTHEAST
> 1999 ES V6 (Sold 2/2011)
drone...got a pic of the stb??Originally Posted by dronesurfboards
ill take a pic of it when i get a chance this week
2002 I4 ES
Tein SS-P
DC Sports upper front strut bar
Ebay rear lower tie bar
Ingalls camber kit in the rear
18 inch Axis Reverbs
225-40-18 Nitto Neo Gen Tires
Love my setup
would anyone be able to tell me where i can get some KYB-GR-2's, i just bought some megan lowering springs and im looking to get it all done soon, thanks alot
1997 DE 5spd
Eibach Prokit
KYB GR-2's
2G strut tower bar
DriftZ 17 X 7 40mm offset
Federal SS 595
14mm rear swaybar
UPDATE:
Megan Racing 32 Way adjustable coilovers
Megan Racing Strut tower bar
18x8 Motegi Racing wheels
225/40ZR18 Falken Ziex 512
On order:
Intrax lower rear sway bar
Powerslot EVO 11" rotors
ebay rear lower tie bar
