i had to notch the tranny cooler and bend the rails forward and back (2 sets of rails) to get them in. then i drilled a hole thru the mounting tabs on the housings and used a longer bolt to mount both the headlights and the tranny cooler. so i have 3 of 4 mounting locations used although i had to cut off the OE JDM upper inside mount (the housings have another tab / hole for mouunting to the bumper right under the grill and he outside 2 bolts should match perfect). they will fit really tight. i also had to trim some of the housing where the headlight meets the ranny cooler. just keep fitting them and you'll see where the plastic needs to be trimmed. i have about 1mm-2mm clearance to the tranny cooler. i believe lazarus actually had the whole tranny cooler tilted to get his in then he mounted the tranny cooler in that state. sorry i have yet to take any pictures because taking them out and re-installing is an ordeal, but they will fit, just take your time and trim in small amounts till you get them in. it took me 9+ hours of trial and error to get them to fit correctly.
