You might want to try resetting your PCM just for the heck of it. As stated in so many posts, don't mess with the idle adjustment screw. To reset the PCM, remove your negative battery cable for 15-20 minutes, then replace it. Make sure you have the security code for your radio handy, because you'll likely need to re-enter that.
Chip
