the adjustable strut bars for the 95-99 eclipse should fit ur car. depending on the one u get u might need to so some modificatilon to the bar like install it backwards or switch the mounts. something simple like that.
as for the integra intake. its gonna fit but not easy. first of all, mitsubishi has a big sensor, the MAS that the integras don't. so you aer gonna need an adaptor plate to connect pipe to the sensor. it looks like this on the left
well since most likely ur gonna use that big adaptor plate ur gonna need fittings. extra ones. the ones that come on the intake won't fit onto that adaptor plate most likely. o yea the nack of the sensor, ur gonna need a big fitting for that too.
the pipework. u might need to so some small modifications to that. the routing of the pipe for the integra intake is similar to the galant but not exactly the same. u might have to turn some pipe maybe do some cutting blah blah blah to get it put in.
